7gego7
Jan 08, 2024Aspirant
RBR750
I have an Orbi RBR750 in the main living area in my home….I want to extend wifi coverage into my garage area…..looking for compatible options. Would something like the EX5000 wifi extender be compati...
7gego7
Garage is about 30 feet away… I’m trying to connect WIZ lights outside garage - won’t connect due to weak WiFi message….but phone connects to my network from that area - no problem.
Jan 08, 2024Guru - Experienced User
K, ya a EAX series would be something to try.
- CrimpOnJan 08, 2024Guru - Experienced User
Do these WIZ lights connect directly to the home WiFi network, or is there "WIZmote" involved?
- 7gego7Jan 08, 2024Aspirant
WIZ lights connect to my wifi network @2.4ghz….the WIZ lights connect without issue if moved into main living area…but won’t connect at garage even though other devices have no issue.
Thanks for the explanation I was distracted by internet comments about whatever the heck that WIZmote-thingy is.
WiFi is really sensitive to structural interference. After these bulbs are initially set up in the house, they can be moved to other locations in the house and immediately join the WiFi network and function, correct? It is only when taken to the garage location that they complain about "weak signal"?
It would be useful to know if the bulbs work in other locations in and around the garage. Garages often do not have very many electrical outlets to experiment with. If the bulbs work most places but fail at the desired location, perhaps there is some metal in the direct radio path between the bulbs and the WiFi units. For example, placing them inside a "really cool looking" metal fixture would not be a good idea.
