Banjo92673's avatar
Banjo92673
RBR750
Issue: Connecting to mQ camera app. How do I do all this as suggested by Chamberland support?   Recommended Router Settings Note: If attempting to change any router settings yourself, be sure to ...
  • CrimpOn's avatar
    Feb 06, 2024
    Netgear Orbi meets all the requirements listed "out of the box" with the exception of allowing inbound ports through the firewall.  I know of no other camera system that requires opening ports. And, none of the customer reviews mention doing this.
    My advice: set it up following the directions that came with it and see what happens.
