RichardLS
Jun 18, 2024Aspirant
RBR750P - No IP address for VPN Connection
I have configured OpenVPN as per Netgear's instructions and it believes it connects from a laptop running Windows, but I cannot access anything on the LAN (e.g., RDP or router via browser). Also, wh...
CrimpOn
Jun 18, 2024Guru - Experienced User
Which version of OpenVPN is installed on the Windows laptop?
Are you able to open the router web admin page using a device connected to the Orbi LAN and open the Attached Devices page? When I do that, the device connected over VPN appears (usually at the bottom of the list) and shows as connection type "VPN"
RichardLS
OpenVPN vv2.6.10
I can view the connected devices, but there are no devices listed as connected to VPN.
