MisterMac
Mar 20, 2025Aspirant
RBR750P inconsistent connection to Canon WiFi Printer from an iPhone 13 or 16
I had the RBR50 Tri wifi5 system and now have the RBR750P Dual wifi6 mesh system. Also upgraded from an iPhone 13 to an iPhone 16. With both routers and both iPhones very infrequently do I have an a...
Mar 20, 2025Guru - Experienced User
Set a IP address reservation for the printer on the Orbi routers web page.
Is the printer ethernet or wirelessly connected?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Something to ask the printer Mfr about.
