Wimbles
Nov 25, 2024Aspirant
RBR750P speeds slow due to LG soundbar
Just upgraded to the RBR 750P (firmware V6.3.8.5_1.4.80) because I thought my old mesh system was failing (Nighthawk AX3600 MK83-100NAS). I recently bought an LG S95QR soundbar and noticed that my sp...
CrimpOn
Nov 25, 2024Guru - Experienced User
Wimbles wrote:
I understand it is due to the wireless subwoofer and rear speakers connecting via Bluetooth over the same channels as the 2.4 GHz frequency
The Orbi 2.4G WiFi can be set to any channel from 1 to 11 (in the US, higher in other countries)
If the soundbar tech support will identify which frequency they use, then pick a different channel for the Orbi.
Wimbles
Talked to LG for the past hour and a half. They were of no use. I found some forums that stated it is possibly the subwoofer causing the interference. I'm guessing I would have to play the guessing game on what channel to use? Thanks for the input!
