NewBear
Apr 17, 2025Aspirant
RBR750/RBR750S, how to best proceed
Hello! We bought the wifi mesh system a few years ago that included an RBR750 Router and 1 additional satellite. We had someone help us install it when we moved into the home that we rent and asked f...
Apr 17, 2025Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem in bridge mode and router and satellites been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
- NewBearApr 17, 2025Aspirant
When I did initially set the Gateway to bridge mode and our wifi/internet went out. I did try to turn off the gateway, the router and the satellite by unplugging each of them from the outlets. I let them sit unplugged for a few minutes before plugging them back in. Afterwards, the Orbi router just stayed magenta and I couldn't access the page to turn bridge mode off of the Gateway which prompted me to reset the Comcast gateway.
I will get back to you later for the manufacturer and model number of our Xfinity modem when I get home. I will try to follow instructions for your 2nd solution either tonight or tomorrow night. Thank you!
