champ_here
Aug 05, 2023Aspirant
RBR750/RBS350 won't sync and have no way to update firmware
Over the last week or so my family has been increasingly complaining about the wifi performance dropping off significantly. I decided to take a look. I had never accessed my router via web browser - ...
CrimpOn
Aug 05, 2023Guru - Experienced User
My guess is the original packaging is long gone. Netgear prints the "kit" number on the box, as in RBK753 ("K"
for "kit") Netgear packaged all sorts of Orbi products into various "Kits".
It would help to report the specific model numbers printed on the product label on the bottom of each unit for the router and two satellites. That will clear up any confusion over which firmware file to use:
- The RBS350 satellite indeed has a firmware file ending in *.img, whereas
- The RBS750 satellite has a firmware file ending in *.chk.
Firmware updates on Orbi systems are indeed awkward. When the actual firmware does not match the latest version shown on the support web site, customers have the option of downloading the firmware, unpacking the zip file, and using the "Manual" tab on the Firmware Update page to load the firmware.
Obviously, when the router reports a satellite as "Out of Sync", it has no reliable connection to the satellite and updating the firmware is going to be a challenge.
It might be worth trying this:
- Power off both satellites.
- On the Attached Devices web page, both satellites should show as "Disconnected" and there should be an option to "Delete" them. Do so.
- Select one of the satellites and do a Factory Reset. i.e. hold a paperclip in that tiny Reset hole when you power on the satellite and hold it until the power LED begins to flash Amber. Let it boot up.
- Use the web interface Basic Tab menu item, "Add Orbi Satellite" (bottom item) to add that one satellite while the satellite is in the same room with the router. (makes watching things a lot easier).
champ_here
Aug 06, 2023Aspirant
After factory resetting each satellite, I cannot get either one to stop flashing white. Instructions on the GUI for setting up the satellites says to wait for it to be solid white. I attempted to sync anyways and the GUI repeatedly said "failed to sync". I noticed under the "attached devices" page, it showed up as connected to the router, even though it said it had failed (and still not sync'd). After trying to use update the firmware using Furrye38's solution, the satellites IP address that was listed under attached devices did not work. I attempted to update it again through the manual update button in the GUI, and it said it failed again. I tried clicking the update button below that and it opened up another page asking for credentials. I typed in my GUI login (admin and password) and I got an error - 401 Unauthorized.
edit: I want it to be known that I am not rushing through any of this. Between yesterday (Saturday) and today, I have spent almost 8 hours working on this and trying different things.
