simdim
Oct 13, 2022Tutor
RBR750/RBS750 AP mode grayed out
Hi all, I need to put real firewall in front of my Orbi RBR750 (V4.6.9.11_2.3.5), but AP MODE/Router is grayed out Am I doing something wrong? Also do I need RBSes to be physically plu...
Oct 13, 2022Guru - Experienced User
What browser are you using? I use MS Edge.
Be sure to clear out all browser caches.
If you select that it doesn't display any AP mode configuration UI at all?
Might need to factory reset and setup from scratch...
