simdim
Oct 13, 2022Tutor
RBR750/RBS750 AP mode grayed out
Hi all, I need to put real firewall in front of my Orbi RBR750 (V4.6.9.11_2.3.5), but AP MODE/Router is grayed out Am I doing something wrong? Also do I need RBSes to be physically plu...
iyang
Oct 13, 2022NETGEAR Expert
Hi simdim ,
Can we know what's function do you enable ?
Does RBR750 is Router mode or AP mode ?
Thanks,
Iris
simdim
Oct 17, 2022Tutor
Mystery of "grayed out" is solved:
If WAN aggregation is set to enabled (WAN port and 1st LAN port are LACP bound) you can not switch to AP mode.
After disabling WAN aggregation - it is allowed.
But here comes a huge BUT with AP mode and wired backhaul ...
Consider the setup:
This works
Internet router -> switch -> WAN port RBR | LAN Port RBR -> LAN port RBS
This is what I need and it does not:
Internet router -> switch VLAN 1 (802.1Q or Port Based)-> WAN port RBR | LAN Port RBR- > switch VLAN 1 (802.1Q or Port Based -> LAN port RBS
VLAN based setup creates a loop with RBR
I had to resort to 2 additional Physical switches and additional cable run to make that setup work .
All my cat6 from RBS are in the basement, in order to get wiring to the first floor where I want RBR I need to run 4 wires between the floors if no additional switches are used, instead of riding a VLAN trunk between basement and first floor switches - this is not good thinking from Netgear ... may be it is time to look somewhere else ... the Orbi product line is just too consumer oriented and it is just too simplistic.
