boredfool
Mar 27, 2023Tutor
RBR750/RBS750, disable radios on satellite
Good Day, I have run into issues where my satellite radios are interfering with the wireless backhaul. I am looking for a way to disable the Wifi radios on the satellite but leave the backhaul up...
- Mar 27, 2023
You'll either need to reduce the power on the RBR to 25%, Under Advanced Tab/Advanced Settings/Wireless Settings
Or turn OFF the RBS since you may not really need it.
boredfool
Mar 27, 2023Tutor
Disabling Wifi on any Orbi system is NOT supported. By design the wifi is enabled 24/7 for it's intended design. Front haul radios are needed so wifi devices can connect to the RBS and thus the back haul used for data flow back to the RBR.
*I understand that, but I do not need the satellite to broadcast Wifi at this time. I would be a fan of lowering the power on the front haul radios for the satellite instead of disabling, but there is not an advanced config option on the satellite interface when connected.
How many RBS are deployed?
*Just one
*Around 1900
What is the distance between the router and
satellite(s)? 30 feet or more is recommended in between RBR and RBS
️ to begin with depending upon building materials when wirelessly connected.
*As I said in the original post, I know and understand they are too close together for the front haul radios, but due to house layout, and device needs I am unable to separate them out any further than they are.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
*Maybe I missed where I could configure this on the router for the satellite, but it is currently set up as auto by default I imagine. Otherwise, unable to really configure anything on the satellite that one can configure on the router.
Also, I know I purchased a router satellite combo that is a bit much for house size, there are plans to move in the future so I am prepared for that, and just trying to make do until then.
Thank you
Mar 27, 2023Guru - Experienced User
- boredfoolMar 27, 2023Tutor
* Yep. Alright, I will click through the router settings again to see if it controls the satellite for that as well since there is no advanced tab when connected to the satellite.
*Yeah, right now only need it for the LAN port.
Thanks again! I will mark your response as the solution.
- FURRYe38Mar 27, 2023Guru - Experienced User
Power on the RBS is controlled by the RBR.
Enjoy.
Enjoy.
*Thanks! I briefly looked at the RBR but then figured it would probably be on the RBS. It made sense to me, but that has led me astray before.
Thanks again!
