boredfool
Mar 27, 2023Tutor
RBR750/RBS750, disable radios on satellite
Good Day, I have run into issues where my satellite radios are interfering with the wireless backhaul. I am looking for a way to disable the Wifi radios on the satellite but leave the backhaul up...
- Mar 27, 2023
You'll either need to reduce the power on the RBR to 25%, Under Advanced Tab/Advanced Settings/Wireless Settings
Or turn OFF the RBS since you may not really need it.
Mar 27, 2023Guru - Experienced User
boredfool
Mar 27, 2023Tutor
* Yep. Alright, I will click through the router settings again to see if it controls the satellite for that as well since there is no advanced tab when connected to the satellite.
*Yeah, right now only need it for the LAN port.
Thanks again! I will mark your response as the solution.
- FURRYe38Mar 27, 2023Guru - Experienced User
Power on the RBS is controlled by the RBR.
Enjoy.
