grinsma
Jun 08, 2022Aspirant
RBR750/RBS750 will not pair in AP mode
If I factory reset the two devices and it comes back in Router mode the system works fine, and the satellite comes up good and we are great. If I move over to AP mode the satellite will not connect...
- Jun 09, 2022
Yes that’s it. The RBR (in AP mode) needs to be connected to the router via its WAN port.
CrimpOn
Jun 08, 2022Guru - Experienced User
Do I read the correctly:
- The router is in 'router mode'.
- The satellite is working and shows on the Attached Devices page as connected as a satellite (top of page)
- The router is changed to 'AP mode' (nothing has been powered off)
- When the router reboots in AP mode, and you connect to the web interface,
the satellite no longer shows as connected? - Plus, the ring light on the satellite turns magenta?
- grinsmaJun 08, 2022Aspirant
Correct!
If I wire the RBS to the RBR then it will show up and out of sync and with an IP of 192.168.1.250 BUT it actually has a 10.0.65.X address and I can access it.
Oddly if I connect the RBS to the switch or the actual router nothing happens, not sure if that is intended.
- CrimpOnJun 08, 2022Guru - Experienced User
That is the way Orbi systems work. Satellites can only function when connected to an Orbi router through one of the router LAN ports.
I do not see in the conversation which firmware release is on the router and satellite.
Firmware is current (V4.6.5.14_2.0.54) on both.
Not relevant to my issue but that means if I had my house rigged with network going back to a 24p switch and I connected a satellite with the intention of having it backhaul to the LAN wired I couldn't? I'd have to rig it up to directly connect to the router? That seems awful.
