grinsma
Jun 08, 2022Aspirant
RBR750/RBS750 will not pair in AP mode
If I factory reset the two devices and it comes back in Router mode the system works fine, and the satellite comes up good and we are great. If I move over to AP mode the satellite will not connect...
- Jun 09, 2022
Yes that’s it. The RBR (in AP mode) needs to be connected to the router via its WAN port.
grinsma
Correct!
If I wire the RBS to the RBR then it will show up and out of sync and with an IP of 192.168.1.250 BUT it actually has a 10.0.65.X address and I can access it.
Oddly if I connect the RBS to the switch or the actual router nothing happens, not sure if that is intended.
CrimpOn
Jun 08, 2022Guru - Experienced User
That is the way Orbi systems work. Satellites can only function when connected to an Orbi router through one of the router LAN ports.
I do not see in the conversation which firmware release is on the router and satellite.
- grinsmaJun 08, 2022Aspirant
Firmware is current (V4.6.5.14_2.0.54) on both.
Not relevant to my issue but that means if I had my house rigged with network going back to a 24p switch and I connected a satellite with the intention of having it backhaul to the LAN wired I couldn't? I'd have to rig it up to directly connect to the router? That seems awful.
- CrimpOnJun 08, 2022Guru - Experienced User
This situation has come up before. The root of the problem is when the Orbi router is not located physically next to the patch panel.
The obvious solution is to install a second Ethernet link from the patch panel to the Orbi location. This is often impractical or costly.
One user faced a similar issue in that his ISP line and modem were in the basement along with the patch panel, but he got better WiFi if the router was located on an upper floor. (Basements are in general a horrible place for WiFi systems.)
His solution was to use a pair of smart switches and VLAN to make both the modem-router and the router-satellite traffic go over one Ethernet cable:
https://community.netgear.com/t5/Orbi/Disabling-automatic-subnet-reconfig/m-p/2031354#M110164
