grinsma
Jun 08, 2022Aspirant
RBR750/RBS750 will not pair in AP mode
If I factory reset the two devices and it comes back in Router mode the system works fine, and the satellite comes up good and we are great. If I move over to AP mode the satellite will not connect...
- Jun 09, 2022
Yes that’s it. The RBR (in AP mode) needs to be connected to the router via its WAN port.
grinsma
So, in a ditch effort, I attempted one last process.
I plugged the RBR into the intended router using the WAN port and factory reset both the RBR and RBS. I configured the RBR via the web console and verified that the RBS came into the console "good" and connected.
I flipped the device over to AP mode, changing _nothing_ but the mode and leaving it DHCP.
Once it was complete I just left it and although the RBS _did_ go Megenta, after a time it went out and the RBR console showed it "good".
I wonder, if it was the WAN port? As I think that is the only thing I changed. I'm used to the idea that in AP mode the WAN port is best to be left alone as it generally either shuts off or fails. This time I just left it.
Either way. I unplugged the RBS, put it where it belongs, and it's working.
