TourBusGuy
Oct 07, 2021Aspirant
RBR752
I just replaced my older Orbi RBR50 with the newer Orbi RBR752. I want to use my two older RBR50 Satellites, but they won't connect to the newer router. I tried to reset them. One did connect for a s...
- Oct 07, 2021
They are not wirelessly compatible with Orbi AX. You can however connect them via ethernet wire.
I want to use my two older RBR50 Satellites, but they won't connect to the newer router. I tried to reset them. One did connect for a short time & then dropped out. Are the older RBR50 Satellites compatible, or do I need to buy more RBR750's?
Thanks....
Oct 07, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
