TourBusGuy
Oct 07, 2021Aspirant
RBR752
I just replaced my older Orbi RBR50 with the newer Orbi RBR752. I want to use my two older RBR50 Satellites, but they won't connect to the newer router. I tried to reset them. One did connect for a s...
- Oct 07, 2021
They are not wirelessly compatible with Orbi AX. You can however connect them via ethernet wire.
I want to use my two older RBR50 Satellites, but they won't connect to the newer router. I tried to reset them. One did connect for a short time & then dropped out. Are the older RBR50 Satellites compatible, or do I need to buy more RBR750's?
Thanks....
Oct 07, 2021Guru - Experienced User
Thanks....
- TourBusGuyOct 07, 2021AspirantI wondered if that would work...I may just buy one more new satellite, as it would cost a fair amount to pay someone to run the cables.
Thank you kindly!!!- FURRYe38Oct 07, 2021Guru - Experienced User
đ
