StefanoVolpi
Jun 09, 2024Aspirant
RBR760 - Problem sync pc time
I noticed that the various computers, laptop that are connected, both via wifi and cable, are unable to synchronize the time (time synchronization failed. Please check your network connectivity and t...
CrimpOn
Jun 09, 2024Guru - Experienced User
What Internet Service Provider (ISP) device is the Orbi router connected to? (exact model number)
- StefanoVolpiJun 09, 2024Aspirant
An Italian ISP: Telecom
Router: Technicolor TIM HUB - model AGHP.
- FURRYe38Jun 09, 2024Guru - Experienced User
IF Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...- StefanoVolpiJun 10, 2024Aspirant
Thanks, i will try the various solutions
