fiqtir
Feb 21, 2023Initiate
RBR760 / RBR760 Wired Backhaul
Hi, I have the RBR760 Orbi router and two RBS760 Orbi satellites. Unlike my last Orbi system, these satellties only have two ethernet ports. I'm trying to set up wired backhaul with little success...
Feb 21, 2023Guru - Experienced User
Are you running through a switch?
OR how do you have them wired in?
It usually switches over to hardwired pretty quickly. (within 5 minutes) if wired properly.
Mine does. (got one hooked up now testing)
What firmware are you on?
did you check through the browser? The app doesn't always display correctly
