vinnie175
Jan 17, 2025Aspirant
RBR760 admin password reset
When I set up this device, I seem to have changed the admin password, and did not save it anywhere. Is there a way to recover this information, or change the password, to be able to get into the admi...
Jan 17, 2025Guru - Experienced User
Try inputting the password 3 times and walk thru the forgot password path in the web browser.
- vinnie175Jan 17, 2025Aspirant
Sorry, I forgot to add this to the list of things I tried. That never popped up as an option for me. The only thing that comes up is a message that says the IP address was changed to 10.0.0.1 to avoid conflict with my modem, and takes me back to the login page. I tried like 10 times to input the wrong information and it does not ask to reset the pasword.
- FURRYe38Jan 17, 2025Guru - Experienced User
I see. Might try this, do same thing with the RBR disconnected from the ISP Modem. See if you can get the recovery to pop up. If no, then you'll need to factory reset the RBR and setup from scratch.
