vinnie175
Jan 17, 2025Aspirant
RBR760 admin password reset
When I set up this device, I seem to have changed the admin password, and did not save it anywhere. Is there a way to recover this information, or change the password, to be able to get into the admi...
CrimpOn
Jan 17, 2025Guru - Experienced User
vinnie175 wrote:
I don't want to have to do a hard reset, as some devices are next to impossible to add to a new network (even if I name the wifi the same, with the same password)
Fortunately, this is not an issue. If the system is reconfigured with exactly the same WiFi credentials, then every WiFi device that was working before will simply reconnect. Think about it. How does a WiFi device know "what happened?" when the WiFi signal stops for a while and then resumes? Every time I replace my WiFi system with a new one, I use exactly the same WiFi credentials and every device simply reconnects.
and.... if I want to "go back" to the previous hardware, it is a simple swap. When the WiFi reappears, devices reconnect.
