Timmy6751232
Jun 27, 2024Aspirant
RBR760 and RBS760 unstable satellite connection
I currently have 3 RBR760s and 6 RBS760s. RBR760 Master (main router set to DHCP) RBS760 Timmy Bedroom (connected to Master's LAN port via 5 port switch) RBS760 Timmy Living Room (connected to Mas...
- Jun 28, 2024
Linked is a great photo of the success after numerous attempts to finding a solution to this network stability issue. This is what I did to find success in providing the greatest range of coverage along with speed.
- I initially started with 9 units
I struggled to get the configurations working with 2 of the RBRs set to access point mode, so I gave up on that idea, this caused me many different failures as I daisy chained, star networked, and tried many different configurations with this cause I wanted maximum coverage using 9 units.
I now only use 1 RBR760 set to DHCP distributing IPs, hard lined 2 of the 6 satellites via super long CAT6 ethernet cord to opposite corners of the estate with the main router in the center of the estate, then wirelessly synced the remaining 4 of 6 satellites to the main router and spread them throughout the other corners of the estate. Totaling 7 devices out of the original 9 purchased for this project. I really wish that there was firmware that allowed an unlimited number of attached devices, it blew my mind that even hard lined RBR760s were considered "satellites".
Thank you to Furry for helping me! Appreciate all the help sir.
Timmy6751232
Jun 28, 2024Aspirant
