Bterry88
Feb 10, 2024Aspirant
RBR760 can only connect to guest network
Hello. If there is a power outage or I want to reset the modem, at seemingly random times almost half of my devices won’t reconnect, and my phone/laptop will only connect to the guest network. I’ve do...
Feb 10, 2024Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Bterry88
Hasn’t made a difference, annoyingly enough. Also having issues with 1 of my rings cameras and smart some identical light switches.
I can’t even get on the web page to change security settings as I’ve seen suggested elsewhere.
- FURRYe38Feb 10, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?Try disabling the following and see:
Armor, Smart Parental Controls or Circle, Traffic Meter.
