Jeff555
Sep 29, 2022Aspirant
RBR760 Device Connections
I had an older Orbi AC3000 with only one satellite and recently upgraded to the RBR760 with two satellites. The problem we are experiencing is we have many devices within a 10 feet radius of one sate...
- Sep 29, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Sep 29, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What devices do you all have connected to the system?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Too Much Wifi: https://youtu.be/UR0viMLISz4
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Jeff555
Firmware v6.3.1.0_1.1.41
ISP is Comcast with a ARRIS Surfboard SB6190
Home is 3,500 sq ft on 2 levels
Used the cable that came with the Orbi between Orbi and the modem
We have 35 devices connected to the system
Of those, I have a PC plugged into one of the satellites and a Smartthings hub and Philips hub plugged directly into the router
For wifi connections, TVs, Rokus, Apple 4K, DTV, laptop, Apple and Samsung phones, ...
You asked about neighbors and I do see a neighbors Orbi device. We have only one neighbor close by, but I do see two other networks.
I have auto and 40 set for channels
- FURRYe38Sep 29, 2022Guru - Experienced User
Jeff555 wrote:
Firmware v6.3.1.0_1.1.41> May want to review new FW updates:
ISP is Comcast with a ARRIS Surfboard SB6190> Might consider a new modem. This model modem has long standing known problems.
Home is 3,500 sq ft on 2 levels> For this size of home having two RBS maybe too much:
Might try turning OFF one RBS or reduce the power from 100% to 25% Under Advanced Tab/Advanced Settings/Wireless Settings
Of those, I have a PC plugged into one of the satellites and a Smartthings hub and Philips hub plugged directly into the router> Do these SmartThings and Philips hubs have there own wifi signal?
You asked about neighbors and I do see a neighbors Orbi device. We have only one neighbor close by, but I do see two other networks. > Can you see what channels they are using?
- Jeff555Sep 29, 2022Aspirant
I went with the new Orbi because I moved to permanent Telework. When that happened, I loved the one satellite on the AC3000 from the FR (one corner of the main level) to the LR (opposite corner of the main level) so that I could use the ethernet port on the satellite. When I did this, Devices being used in the FR were pausing and disconnecting a lot. But, I previously had not problems between that modem and the older Orbi setup.
I will check FW updates this afternoon for sure.
There is definitely 30 feet between all 3 devices (RBR to each RBS and RBS to RBS).
The neighbors Orbi appeared to be using Channel 5 for sure, but now all of a sudden I cannot see it. My system appears to be using channel 9 with 40. I will change that to 48 as you suggested when I can interrupt work.
The hubs use the network, not wifi.
Try lowering the power to 25%.
Try usnig channels 11 and 48
