Jeff555
Sep 29, 2022Aspirant
RBR760 Device Connections
I had an older Orbi AC3000 with only one satellite and recently upgraded to the RBR760 with two satellites. The problem we are experiencing is we have many devices within a 10 feet radius of one sate...
- Sep 29, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jeff555
Firmware v6.3.1.0_1.1.41
ISP is Comcast with a ARRIS Surfboard SB6190
Home is 3,500 sq ft on 2 levels
Used the cable that came with the Orbi between Orbi and the modem
We have 35 devices connected to the system
Of those, I have a PC plugged into one of the satellites and a Smartthings hub and Philips hub plugged directly into the router
For wifi connections, TVs, Rokus, Apple 4K, DTV, laptop, Apple and Samsung phones, ...
You asked about neighbors and I do see a neighbors Orbi device. We have only one neighbor close by, but I do see two other networks.
I have auto and 40 set for channels
Sep 29, 2022Guru - Experienced User
Jeff555 wrote:
Firmware v6.3.1.0_1.1.41> May want to review new FW updates:
ISP is Comcast with a ARRIS Surfboard SB6190> Might consider a new modem. This model modem has long standing known problems.
Home is 3,500 sq ft on 2 levels> For this size of home having two RBS maybe too much:
Might try turning OFF one RBS or reduce the power from 100% to 25% Under Advanced Tab/Advanced Settings/Wireless Settings
Of those, I have a PC plugged into one of the satellites and a Smartthings hub and Philips hub plugged directly into the router> Do these SmartThings and Philips hubs have there own wifi signal?
You asked about neighbors and I do see a neighbors Orbi device. We have only one neighbor close by, but I do see two other networks. > Can you see what channels they are using?
- Jeff555Sep 29, 2022Aspirant
I went with the new Orbi because I moved to permanent Telework. When that happened, I loved the one satellite on the AC3000 from the FR (one corner of the main level) to the LR (opposite corner of the main level) so that I could use the ethernet port on the satellite. When I did this, Devices being used in the FR were pausing and disconnecting a lot. But, I previously had not problems between that modem and the older Orbi setup.
I will check FW updates this afternoon for sure.
There is definitely 30 feet between all 3 devices (RBR to each RBS and RBS to RBS).
The neighbors Orbi appeared to be using Channel 5 for sure, but now all of a sudden I cannot see it. My system appears to be using channel 9 with 40. I will change that to 48 as you suggested when I can interrupt work.
The hubs use the network, not wifi.
- FURRYe38Sep 29, 2022Guru - Experienced User
Try lowering the power to 25%.
Try usnig channels 11 and 48
I checked out the Firmware and it says I am current.
Changed the channels as recommended and reduced the power (only to 50%, wanted to try that first).
The latter process on the power changed everything. Devices appear connected as they should be based on their current location.
Unless you have any other recommendation, I truly appreciate your assistance. Thank you so much!
