Jeff555
Sep 29, 2022Aspirant
RBR760 Device Connections
I had an older Orbi AC3000 with only one satellite and recently upgraded to the RBR760 with two satellites. The problem we are experiencing is we have many devices within a 10 feet radius of one sate...
- Sep 29, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jeff555
I checked out the Firmware and it says I am current.
Changed the channels as recommended and reduced the power (only to 50%, wanted to try that first).
The latter process on the power changed everything. Devices appear connected as they should be based on their current location.
Unless you have any other recommendation, I truly appreciate your assistance. Thank you so much!
Sep 29, 2022Guru - Experienced User
Enjoy. 📡
