toto123456's avatar
toto123456
RBR760 et WIFI 7
Hi, does anybody know if it is or it will be possible to upgrade the RBR760 (AX5400) to wifi 7, or will I have no other choice than to buy a new router ? Thanks
  • plemans's avatar
    Mar 30, 2024
    Wifi 7 is a hardware change. You'd need a new router to get wifi 7.
    But I'd hold off. There really isn't much for devices that support wifi 7 yet so unless you've recently picked up quite a few, you won't really notice a difference.
