MJames68123
Dec 29, 2023Follower
RBR760, Firmware Upgrade to v7, Does Anyone Have a Release Date ???
Recently purchased a new RBK762 to replace a dead RBR50... and frankly it was a huge let down! My previous RBR50 router with one RBS50 satellite were great until it's passing. Big selling points...
- Dec 29, 2023
The original RBR50 Orbi does not allow users to create separate SSIDs for the 2.4G and 5G WiFi bands. (I still have one.) There was a hack 5-6 years ago that worked briefly, but no firmware version since then has allowed this.
With the v7 update, firmware for many Orbi AX systems, including the RBR750, added a new feature which allows users to create an additional WiFi SSID. Netgear calls it "IOT" implying that it should be used for "Internet of Things" devices, but it can be named anything and used for anything. Like the primary and guest WiFi features, both the 2.4G and the 5G channels must have the same name. However, the IOT feature allows users to enable the feature for 2.4G, 5G, or both. (and obviously for neither). Thus when connecting a new device, the user can temporarily turn off the 5G channel (and any devices connected to it will lose connection), add the new device with the smartphone and device connected to the remaining 2.4G channel, and then reactivate the 5G IOT channel. This "solves the 2.4G problem".
When (or if) Netgear will release v7 firmware for the RBR760 is unknown.
There are different categories of devices:
- Anything with a keyboard or camera usually connects easily. My Simplisafe, for example, allows me to select the correct WiFi from the control panel, enter the password on the control panel, and.... "connected". With cameras, the smartphone app creates a QR code that is shown to the camera, and... "connected"
- It is only devices that have no means of entering information (garage door openers, smart plugs, smart bulbs, etc.) that rely on the smartphone app to inform the device of the WiFi network and password. Some, like Wyze smart plugs use Bluetooth. "no problem"
- Most other devices temporarily create a WiFi host, the smartphone connects to the host and communicates the WiFi information which the device uses to connect to the WiFi network... "done" If the app puts up annoying messages about "MUST have 2.4G WiFi", just ignore the message and complete the setup.
- Some apps are defective. Frankly, no one has a good explanation for what whoever programmed them was thinking, but either (a) they recognize the phone is already connected to a 5G WiFi system and refuse to proceed, or (b) they inform the device of information about the 5G WiFi connection that the device cannot use. If they would simply say, "Look for this WiFi and use this password", all would be good.
So, what does a person do when unwilling to "send the damn thing back" and buy something that works? Here are the strategies that seem to be used:
- Move the device and smartphone so far away from the Orbi WiFi that the only possible connection is at 2.4G. Turning down the Transmit Power on 5G (not on 2.4G) sometimes makes this possible. For example, power off all the satellites so that only the router remains active. Set the router power to 25%. Disconnect and reconnect the phone. It may be necessary to temporarily place the device in a different location so that both it and the phone can detect only the 2.4G signal.
- Keep an old WiFi system on hand that can enable only the 2.4G channel. Temporarily plug it in instead of the Orbi with exactly the same WiFi credentials, perform the setup, and they swap the Orbi back in again.
- Create a Hot Spot on one cell phone using LTE data that has exactly the same credentials. Power off the Orbi, perform the setup using a different device that is connected to the Hot Spot, etc.
I have a box full of smart plugs, smart bulbs, etc. etc. that connected to the Orbi with no problem.
Yes, using any WiFi extender product that allows disabling the 5G signal (or doesn't have one to begin with) allows you to create a unique WiFi network that the smartphone and the device can be connected to. Once the device is operating, it will have to stay connect to the extender, but the phone does not. Page 19 of the EX3110 user manual describes how to disable the 5G WiFi
https://www.downloads.netgear.com/files/GDC/EX3110/EX3110_UM_EN.pdf
