SteveHyland
Feb 13, 2025Aspirant
RBR760 MULTIPLE ISSUES
My RBR760 is connected to the internet via the D-Link DSL-4320L. It (and two satellites) worked fine until yesterday. Then for some reason the RBR760 went offline. (The DSL4320L modem was fine - a...
- Feb 14, 2025
Many thanks to all who offered advice.
In the end, I deleted the app and then methodically reconnected the DSL and RBR.
I'm now up and running again (including with the ORBI app).
It was a bit unstable at first (depending on the internet port I selected on the DSL-4320L), but seems to have settled down. I suspect the "double NAT" issue may be at play, but frankly the solution is beyond my technical capabilities - the last thing I want to do is tamper with the DSL settings and not be able to backtrack.
If problems continue, I'll end up having to call in an IT specialist (for what should have been an easy plug in!).
SteveHyland
I mentioned above that the "satellites are working". I should have said "appear to be working". I now believe I’m getting reduced internet coverage from the RBR760 router itself rather than its satellites.
