MussMan
Sep 18, 2022Aspirant
RBR760 Network issues
I have an RBR760 with 2 satellites and I'm having a lot of connectivity issues. Many of my wifi devices will intermittently connect to the network with Internet. When I can't connect to the Inter...
MussMan
See my answers in bold italics below. Thanks for any help.
Motorola SURFBoard SB6141
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. Check - It's a good CAT6 cable.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS
to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
My home is a single level and a basement. 5,000 sq ft combined. The router is almost exactly in the center of the home in the basement. The satellites are on the main level at opposite extreme ends of the home. I'd guess they're around 50-60 feet each straight line from the router, but there are obviously walls between them as well.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
I was using Auto on 2.4GHz and 40 on 5 GHz. I just tried changing it to 1 on 2.4 and 40 on 5 and I'll see what happens.
I regularly see fairly weak signals from 1-2 neighbors. Sometimes 3, depending on which side of my property I'm on.
MussMan
No change with the updated WiFi channel settings.
- ekhalilSep 18, 2022MasterWhat devices do you have connectivity issues with? All devices?
Do you have AX features activated on Orbi? Any AX devices in use?
What wired devices do you have in the network?
Is any of your satellites wired to the router?- MussManSep 19, 2022Aspirant
Connectivity issues are with all devices (even a wired TiVo).
I believe AX is activated if it is activated as a default setting. I don't believe I have any AX devices.
I'm using 2 wired TiVo boxes, a wired security system (which hasn't had connectivity issues), a wired SmartThings controller, wired telephone modem, a wired MoCA device for my TiVo network, and an ethernet switch to handle the extra wired devices.
None of my satellites are wired.
On the wired TiVo that is having issues: When it's connected via Ethernet, it sees the other devices on my network (through the MoCA network if you're familiar with that), but it doesn't get an internet connection. This allows me to watch on my other devices, but it only updates the guide info when I'm connected to the internet. To get around this issue, I disconnect the main TiVO from ethernet and connect it to the network via WiFi about once per week to download the info. Then I reconnect it to ethernet so my other TiVO boxes can connect to the main box and watch.
I don't believe the satellite distance is causing the issue. Even when the satellites aren't connected, I'm having the same connectivity issues.
Also note, I was using an older NightHawk router before I moved to the Orbi system and all of my devices were working normally.
