thenewbguy
Dec 08, 2022Aspirant
Rbr760 not a fan of samsung phones
I recently got this orbi kit and my phones seems to never be able to connect to the 5ghz band. I'm using a sg21 ultra and a galaxy a71 both having the same issue.
Dec 09, 2022Guru - Experienced User
What OS is loaded on the phones?
Can you disable the AX mode on the RBR?
How is the wifi settings configured on the RBR?
Try setting manual channel 1 on 2.4Ghz and 40 on 5Ghz.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Do they connect on 5Ghz if you turn OFF the RBS?
thenewbguy
Dec 09, 2022Aspirant
Tried all those options, even standing directly next to the router with and without the satellite being on, no change
Phone is running android 12, one ui 4.1
- FURRYe38Dec 09, 2022Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- thenewbguyDec 09, 2022AspirantIt's a huawei ont. The wifi is turned off so there's no interference from that side
- FURRYe38Dec 10, 2022Guru - Experienced User
That would be good however if there is a built in router as well, I presume so if there is wifi, this could cause problems as well. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
