Jjersey63
Aug 08, 2022Apprentice
RBR760 Satellite via web page
Weird issue - wren I look at my web page for connected devises both my satellites show disconnected however, they are listed 126 times - 2 MAC addresses but repeated many times. Nothing shows connec...
- Aug 09, 2022
Try a factory reset...
Jjersey63
So I rebooted everything in order, waited and all works but still the same results. I didn’t factory reset - what is the best way to do this? I have a backup config to restore.
Aug 08, 2022Guru - Experienced User
I would use the RBRs web page under Advance tab/Advanced/Backup and use the Erase button here. When you do this, I would then press the reset button on the RBS for 15 seconds then release. Walk thru the setup wizard using a wired PC and web browser and complete the setup process. I would first check the RBS on the RBRs web page after you complete the setup wizard and see what it shows.
