absentx
Jul 15, 2024Aspirant
RBR760 Satellites Wired Backhaul not working through Araknis POE managed switch
Hello, I have an RBR760 router with three RBS760 satellites and arranging the wired backhaul through my Araknis 210 switch has been nothing short of frustrating. Here is where I am at and some hi...
- Jul 15, 2024
When I did this VLAN config on a NG managed switch, I had my RBS wirelessly connected. Then configured the managed switch for the VLAN and applied the changes. I don't think the switch should need any rebooted or power cycle. After the config was applied, I then connected the RBS via ethernet, one at a time, allowed for 5 minutes to settle in. Then tested each RBS with a phone and pad. However, not sure if same thing will work with a different branded switch, so might be good to find a GS 105 or GS 305 non managed switch to connect the RBS too and be done with it. đ
Jul 15, 2024Guru - Experienced User
Does the RBS wired backhaul work if you replace the managed switch with a non managed switch? Something like NGs GS 105 or GS 305?
Try disabling any IGMP and Green Ethernet protocols on this switch.
