absentx
Jul 15, 2024Aspirant
RBR760 Satellites Wired Backhaul not working through Araknis POE managed switch
Hello, I have an RBR760 router with three RBS760 satellites and arranging the wired backhaul through my Araknis 210 switch has been nothing short of frustrating. Here is where I am at and some hi...
- Jul 15, 2024
When I did this VLAN config on a NG managed switch, I had my RBS wirelessly connected. Then configured the managed switch for the VLAN and applied the changes. I don't think the switch should need any rebooted or power cycle. After the config was applied, I then connected the RBS via ethernet, one at a time, allowed for 5 minutes to settle in. Then tested each RBS with a phone and pad. However, not sure if same thing will work with a different branded switch, so might be good to find a GS 105 or GS 305 non managed switch to connect the RBS too and be done with it. đ
absentx
Well, I am trying to avoid buying a different switch, I really like this one and it came as part of our media buy with a new house. With that said, I could replace the switch if for some reason this one just won't work.
I have EEE settings disabled on all ports.
In the IGMP snooping settings, it says that IGMP snooping is disabled. However, further down on that page under "router settings" it shows VLAN ID as 1 and then under the column "Router ports auto learned" it says "Enabled" I am not sure what that all means.
Jul 15, 2024Guru - Experienced User
Give this a try on your managed switch and see if this could help:
Not sure if this will or not since you have a different managed switch. If it doesn't you can just add a GS series non managed switch behind the RBR alone with the managed switch and just connect the RBS to the GS series switch. I run a couple of switches behind my RBR. đ One is sepecifically for my RBS that are ethernet connected.
- absentxJul 15, 2024Aspirant
Okay cool, yeah that was my next move (buying a small un managed switch for the satellites) but I figured I would take one more shot at troubleshooting this specifically with the managed switch.
I have tried the VLAN setup you suggested but it doesn't seem to hold after a reboot like in the other situations. I did however only input the VLAN settings and Apply, I did not restart the switch, do you think that is necessary to truly try the config?
I think I am ordering a small unmanaged switch to run the satellites from and just put this to bed. Thanks for the help.
- FURRYe38Jul 15, 2024Guru - Experienced User
