randomtask
Dec 19, 2023Tutor
RBR760 Slow Wired Speeds
So I had very similar issues with the RBK753 system so shame on me for purchasing the RBK763 hoping for better... Wired devices have slower speeds than wireless devices and, to me, it seems to b...
Mikey94025
Dec 19, 2023Hero
randomtask wrote:So I had very similar issues with the RBK753 system so shame on me for purchasing the RBK763 hoping for better...
Wired devices have slower speeds than wireless devices and, to me, it seems to be some kind of QoS functionality that seemingly cannot be turned off. For example, I can start a download and it starts at 100Mbps and sustain that speed for only a few seconds before getting ramped down and down and down to around 20Mbps.
I'm fairly certain this has to be a common issue with this hardware but I have not been able to determine a resolution. I've tried various things like disabling IPv6 and UPnP based on these things seeming to work for other people in similar situations but this does not work for me. I have also replaced the ethernet cables between the modem and the router and device(s) in question.
Is anyone aware if there is indeed some QoS that these devices employ and, if so, can it be disabled?
I am not aware of any default QoS features in the Orbi AX systems that cannot be disabled. What you describe (slow wired speeds) is not commonly reported here. Your situation is also curious because why would wireless traffic not be affected but wired does?
How many wired devices do you have that exhibit this issue? If only one, the issue may be with that device itself and that would explain why it persists after replacing your older Orbi. Please explain that device, its version and OS, and in detail how it connected wired to the network. Is there a network dongle, a switch inbetween somewhere, etc.?
Fortunately there are some simple tests you can try. Connect your wired device directly to the modem and see if the problem occurs. Then connect wired directly to the Orbi base and do the same. The results will help us determine next steps.
randomtask
Dec 20, 2023Tutor
I have two separate workstations exhibiting the same behaviors. They are both running Windows 10x64 22H2. One of those workstations is a new build that replaced an older machine that was also exhibiting the same behavior. One is connected directly via the main router while one is connected to a wire-backhauled satellite. I have connected one of the workstations directly to the modem and achieved stable Gigabit speeds. I also was able to put an old Nighthawk router in place of the Orbi system and connected both workstations and had stable speeds.
There are no dongles, but I do have 1 gigabit switch on the network. However, it is not BETWEEN the Satellite and workstation (not sure if that matters or not).
