walterLite
Oct 09, 2023Aspirant
RBR760
I would like to use the Orbi in AP mode however r it shows that I need to use an Cable to connect my Cable modem to the Orbi . this is very impractical because No i would have to run cabling ...
michaelkenward
Oct 09, 2023Guru - Experienced User
walterLite wrote:
I would like to connect the cable modem via WIFI to the ORBI AP box - how is this done
No can do. As CrimpOn says, the Orbi router has to be wired to the modem.
The way to connect things to the wifi is to use an Orbi satellite to connect to the Orbi router.
You can plug Ethernet devices into the Orbi satellite. Not enough LAN ports? Plug a switch into the satellite and connect things to that.
If you want to wire the Orbi satellite to the Orbi router you can user Powerline Ethernet to connect them.
walterLite
Oct 17, 2023Aspirant
Not available From Netgeer oh no ....
- CrimpOnOct 17, 2023Guru - Experienced User
Netgear indeed makes PowerLine adapters:
https://www.netgear.com/home/wired/powerline/
I have PowerLine installed (not Netgear). When on the same electrical circuit and over a reasonably short distance, the performance is amazing. On different electrical circuits (in the same breaker box) and a longer distance, PowerLine can be less impressive.
- michaelkenwardOct 18, 2023Guru - Experienced User
I have also used a mixture of Netgear and third party Power line devices. They work together just fine.
I use Powerline to connect an MS90 satellite to an MR 90 router. Works well.
Powerline is effectively an industry standard. This means that you can buy single plugs from other brands and add them to Netgear plugs.
This is useful because Netgear sells only two (or more) plug sets. Some brands are happy to sell singletons. So you can buy a two-port plug, or a wifi access point plug, and add them to your network.
