HigSal
Apr 01, 2024Follower
RBR760
How to use 2 additional satellites from a second RBR760 system? I pressed synch button, both new satellites end up blue but are not recognized.
Apr 02, 2024Guru - Experienced User
Not seen on the RBRs web page or the Orbi app?
Power OFF the original RBS while working with the incoming RBS.
Be sure incoming RBS are at some firmware level is the original system is:
Factory reset the RBR and RBS and walk thru the setup routine. Follow this:
