Rikerrock
Apr 12, 2025Tutor
RBR8 with two RBS840 and Two RBS750 issues
So I have had this for some time The satellites are all connected via wire and all switches are gigabit wired. I have 500/500 fiber. It tests this speed at the router. The GUI of the router is sl...
Apr 12, 2025Guru - Experienced User
What is RBR8? RBR should be RBR###
What web browser are you using? Happens in other browsers?
What FW version is loaded on the RBR and all RBS?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channel configurations are currently set on the router?
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
