Rikerrock
Apr 11, 2025Tutor
RBR8 with two RBS840 and Two RBS750 issues
So I have had this for some time The satellites are all connected via wire and all switches are gigabit wired. I have 500/500 fiber. It tests this speed at the router. The GUI of the router is sl...
CrimpOn
Apr 11, 2025Guru - Experienced User
My vote is for a typo. It is fortunate but frustrating that Netgear has customers in almost every county. It can be quite some time before the Original Poster discovers a reply.
Rikerrock
Apr 12, 2025Tutor
I bought a three unit system RBR840 with two RBS840 sats from costco and added the two RBS750 that came with an older three system orbi mesh. When I called tech years ago when I got the RBR840 they told me the two RBS750s would work. They have and do show up as satellites.
- RikerrockApr 12, 2025Tutor
What is RBR8? RBR should be RBR###
Sorry RBR840
What web browser are you using? Happens in other browsers?
Tried with two browsers and a hardware unit called FING
What FW version is loaded on the RBR and all RBS?
Model Name Device Name Current Firmware Version StatusRouter RBR840 Matrix0007 V4.6.14.5 No New Firmware Available Satellite RBS750 Green Room V7.2.6.21 No New Firmware Available Satellite RBS750 Theater Room V7.2.6.21 No New Firmware Available Satellite RBS840 Family Room V4.6.14.5 No New Firmware Available Satellite RBS840 Master Bedroom V4.6.14.5 No New Firmware Available What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
It's a frontier Fiber ONT; Speed tested at that with a laptop is 500/500
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.What is the size of your home?
Sq Ft? Approx 3400
What is the distance between the routerRouter is in the garage. One sate RBR840 is in family room approx 35feet from the router in the main room we hang out in. Then a RBR750 is about 35 feet from the router and 35feet from the family room one on the other side of the house; forms like a triangle. They on second story about 35 feet from the family room there is another RBR840 and a RBR750 about 35 feet from that on other side house. Nothing is directly above each other. All are hard wired.
and satellite(s)
️? 30 feet or more is recommended in between RBR
and RBS
️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channel configurations are currently set on the router?Wireless Settings (GENERAL) Region North America 2.4 GHz Channel Auto (8) 2.4 GHz Wireless mode: Up to 1147 Mbps 5 GHz Channel 36 + 40 + 44(P) + 48 5 GHz Wireless mode: Up to 2402 Mbps Region Selection Region: Advanced Wireless Settings (2.4 GHz b/g/n/ax) Enable 20/40 MHz Coexistence Enable WMM (Wi-Fi multimedia) settings (2.4 GHz b/g/n/ax) CTS/RTS Threshold (1-2347): Preamble Mode Transmit Power Control Advanced Wireless Settings (5 GHz 802.11a/n/ac/ax) Enable WMM (Wi-Fi multimedia) settings (5 GHz a/n/ac/ax) CTS/RTS Threshold (1-2347): Preamble Mode Transmit Power Control Try disabling the following and see:
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.All have been disabled before.
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Yes
Turn off and unplug modem.
Turn on computers and rest of network.Has been done prior
No. Waiting to have time so family does not kill me with it down too long.
Thank you.
- FURRYe38Apr 12, 2025Guru - Experienced User
You need to downgrade the 750 series back to v.4 FW. V4 FW and v7 FW is not compaible between each other.
I see NG has not released v7 FW for the 840 series to date either.
Also for that size of home the router unit and maybe two RBS deployed should be enough. Having 4 RBS deployed may cause problems: https://youtu.be/UR0viMLISz4
Can you test with both RBS750s turned OFF for now?
If you think you need more then that, try reducing the power on the system on the RBRs web page from 100% to 25%. Under Advanced Tab/Advanced Settings/Wireless Settings
Thanks. Will try what you said.
