dpalmet
Jun 04, 2022Follower
RBR840 - Not showing 2.4GHz network at all
I've had the orbi RBR840 for about two years. I have a number of FEIT smartbulbs that are connected to my 2.4Ghz radio. When I tried adding another FEIT smartbulb recently, I couldn't locate the 2.4G...
Mikey94025
Jun 04, 2022Hero
It is odd that you don't see any 2.4Ghz wireless network from your Orbi. A factory reset may be required. If your Orbi's admin website indicates that it is indeed transmitting a 2.4Ghz wireless network, then these settings changes may improve compatibility with older 2.4Ghz wireless devices like your Feit lightbulb:
- Go to the web admin portal at http://orbilogin.com/
- Click to the Advanced tab, Advanced left menu, Wireless Settings
- Set CTS/RTS Threshold to 2347 for both 2.4hz and 5Ghz networks
- Press Apply
See if that helps. If problems still persist, next try disabling AX mode for the 2.4Ghz band:
- Go to http://orbilogin.com/
- Click to the Advanced tab, Setup left menu, Wireless Setup
- Uncheck "Enable 2.4G" under the top Enable AX section
- Press Apply
