rjddsc
May 29, 2020Follower
RBR840 Add Satellite
I need to add a satellite to my Orbi RBR840 system and I cannot figure out which satellite model is compatible with it? You would think the Netgear site would link to the appropriate satellite from t...
CrimpOn
Jul 06, 2020Guru - Experienced User
rjddsc wrote:I need to add a satellite to my Orbi RBR840 system and I cannot figure out which satellite model is compatible with it? You would think the Netgear site would link to the appropriate satellite from the product page but they don't.
Yes, another "ding" for Netgear. The Support web site links to a page for the RBS850 satellite, which says very clearly on page 4 of the Product Data Sheet, "What do I need? Requires RBS850 router SOLD SEPARATELY"
https://www.netgear.com/images/datasheet/orbi/RBS850.pdf
Alas, searching for RBS840 does not produce a link to a product data sheet for that satellite. Instead, there is a link to the RBK842 package. Really annoying.
So, it is 100% guaranteed that an RBS840 satellite will integrate with the RBR840 router. 100%.
Ordinarily, one would think that the RBS850 satellite would as well, but with no documentation, the only person who might know would be someone who owns an RBR840 and has added a satellite.
OR.... Netgear provides 90 days of "complimentary support" with purchase of an Orbi system. If this system is "new", I would think that Netgear support ought to be able to give a definite answer.
sdhar
Jul 06, 2020Aspirant
Customers with Orbi Router RBR840 (RBK 842) can only go with 2 extended 3rd or 4th satilites. RBS850 Still not available in the market !!!!! Netgear is just advertising and trying to encourage to buy expensive routere. Or Buy another Outdoor Satilite RBS50Y (hard time to connect to the existing Wifi 6 system. Returning Brand new to Costco today !!
