rjddsc
May 29, 2020Follower
RBR840 Add Satellite
I need to add a satellite to my Orbi RBR840 system and I cannot figure out which satellite model is compatible with it? You would think the Netgear site would link to the appropriate satellite from t...
Jul 06, 2020Guru - Experienced User
Any progress on this?
Most RBS8 series will work. You can get a RBS50Y and use it in extender mode.
Be aware that current world evens may impact the market and new inventory.
rjddsc wrote:I need to add a satellite to my Orbi RBR840 system and I cannot figure out which satellite model is compatible with it? You would think the Netgear site would link to the appropriate satellite from the product page but they don't. Want to be sure I get the right one so I appreciate your help.
