joekent28
Feb 04, 2025Follower
RBR840 keep dropping connecting
RBR840 Router and two satellites have all worked great for over a year using our old internet provider. Switched to Fiber internet, and now it won't stay connected. It works GREAT when working, but a...
Feb 05, 2025Guru - Experienced User
what actual gateway is it from your ISP?
Not all off them are decently designed since they're supplied to ISPs.
Sometimes the bridge mode option is best, others you leave the isp in router mode (disable its wifi) and put the netgeare in access point mode.
