ahussain
Apr 13, 2020Initiate
RBR840 router is not showing on computer
My Sony VAIO SVF15N28PXB with Window 10 Pro operating system with Intel(R) Wireless-N 7260 network adapter can not see the RBR840 router. It sees all other Wireless Networks. All other devices in the...
- Apr 13, 2020
Please post about this over in the Orbi AX Forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Ensure your WiF adapter drivers are up to date.
Good Luck.
ahussain
Hello FURRYe38 (Guru),
I disabled and enabled the network adapter few times before I posted my note on the board. Before doing so, I also checked for driver updates. My computer told me driver was up-to-date.
As per your suggestion, I went through the steps one more time. As well as reset everything once more. Nothing worked still.
Good news however... I performed the driver update check once again also. And there was a new update today, all of a sudden. After the update, the Orbi network is showing up.
Nonetheless, many thanks to you for taking the time to reply to my post.
Consider this solved.
Apr 13, 2020Guru - Experienced User
Good to hear. Glad the driver update fixed it.
Please mark your thread as solved so others will know.
Please remember to post over in the Orbi AX forum for your future needs.
Enjoy. :smileywink:
