Takeda
Mar 15, 2022Aspirant
RBR840 Router network not visible
After loading windows 10 on a Lenovo T560 Thinkpad, other networks are visible, but not my RBR840 wifi router.
I have tried uninstalling, and reinstalling the device driver on the Intel Dual Band Wireless AC 8260 adapter.
Ensure the wifi adapter drivers are up to date.
Disable AX mode on 2.4 and 5Ghz on the RBR...
- TakedaAspirant
Thank you! Disabling AX worked. The previously installed windows 10 worked with AX before I reinstalled it.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
