sugigu
Jul 25, 2023Follower
RBR840 /w Firmware Version V4.6.14.3_2.3.12 /w adguard home
afternoon, does any one use RBR840 with adguardhome?
point DNS to it's own LAN IP, ex. 192.168.1.7, which host a DNS server
after setting saved, ext network just fine, but after 10 ~ 20 mins, ext network will break, mcan't connect to anything
since LAN still work
before Firmware Version V4.6.14.3_2.3.12 all OK, start disconnect after V4.6.14.3
1 Reply
Does the system work normally with out the Adguard configuration?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
