dcsquires's avatar
dcsquires
Follower
Apr 21, 2021
RBR850 - access 2.4 wireless network
I have a couple of devices that use 2.4 GHz to connect and I can't connetct them to my RBR850 router. How do I connect 2.4 ZGHz devices to the router?
Thank you!
DCSquires
1 Reply
  • FURRYe38's avatar
    So you might try changing the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was. Under Advanced Tab/Advanced Settings/Wireless Settings
    Contact the mfr of these device for additional help, support and infornation regarding there product
