Dries2
Feb 29, 2020Guide
RBR850 - Access Point + wired backhaul & security issues
Hi all, I've bought the RBK821 (RBR850+RBS850) combo, but it has given me quite some headache... I already have a router installed (Fritz!Boz 7590) which needs to function as a router, becaus...
- Mar 01, 2020
What impractical cabling is preventing Senario #3?
Your switch you have maybe a factor, thought its non managed, it has green ethernet features which causes problems for Orbi systems:https://www.cisco.com/c/en/us/products/collateral/switches/small-business-100-series-unmanaged-switches/datasheet_C78-582017.html
We've seen issues before with users switches having green ethernet.
Any chance you have a different switch with out Green Ethernet features?
Dries2
Feb 29, 2020Guide
Hi Johnny,
Thank you for your feedback.
Are you sure?
According to this KB article:
it should be possible to have a switch in between.
johnny5126
Feb 29, 2020Aspirant
Maybe but mines connected directly and I have no issues at all.
- FURRYe38Feb 29, 2020Guru - Experienced User
Yes direct connected should work.
