Dries2
Feb 29, 2020Guide
RBR850 - Access Point + wired backhaul & security issues
Hi all, I've bought the RBK821 (RBR850+RBS850) combo, but it has given me quite some headache... I already have a router installed (Fritz!Boz 7590) which needs to function as a router, becaus...
- Mar 01, 2020
What impractical cabling is preventing Senario #3?
Your switch you have maybe a factor, thought its non managed, it has green ethernet features which causes problems for Orbi systems:https://www.cisco.com/c/en/us/products/collateral/switches/small-business-100-series-unmanaged-switches/datasheet_C78-582017.html
We've seen issues before with users switches having green ethernet.
Any chance you have a different switch with out Green Ethernet features?
Bandito
Feb 29, 2020Luminary
Why do you need the Fritzbox router on the switch? The Fritzbox router should go directly into the WAN port on the Orbi router, then you can hang the switch off of the LAN port on the router and you should be okay, but It would still be better to directly connect the satellite to the Orbi router, just to be safe.
Dries2
Mar 01, 2020Guide
Hi all,
Thank you for all your help!
First a practical remark: it is not very easy to do something about my cable-setup. All devices mentioned are in different rooms (often different floors) and e.g. installing an additional network cable that goes directly from my RBR850 to my RBS850 would involve drilling some holes in walls and ceilings. This is a scenario I would like to avoid (then I prefer two cheaper non-mesh access points instead).
Some more input on the devices involved:
* My switch is an unmanaged switch (Cisco SG102-24 Compact 24-Port Gigabit Switch)
* My router is a Fritz!Box 7590, which is connected to a cable-modem, a CBN CH6643E (provided by the ISP);
A direct link between the ISP modem and the RBR, as suggested by FURRYe38 is also not possible. First of all, the router needs to be in between. Secondly, my cable setting does not allow it (all cables from all rooms in the house go to one central location where my switch is. From there, it is connected to the router, which is connected to the modem).
And also the scenario where I would connect the router to the WAN port of the RBR850 and the switch to the LAN port is not possible, because they are not in the same room.
An overview of the scenario's I have tried + outcome.
Scenario 1:
Setup:
* Orbi Router (WAN port) -> Switch -> Fritzbox Router
* Orbi Satellite (LAN port) -> Switch -> Fritzbox Router
Outcome:
- Satellite is not listed in "attached devices" => no mesh;
+ All Wifi SSID's are secured;
Scenario 2:
Setup:
* Orbi Router (LAN port) -> Switch -> Fritzbox Router
Outcome:
+ Satellite is listed in "attached devices" => mesh;
- The 5Ghz network broadcasted by the satellite is unsecured;
Scenario 3:
Setup:
* Orbi Satellite (LAN port) -> Orbi Router (LAN port);
(for testing purposes - not able to have this as a final setup due to impractical cabling)
Outcome:
Scenario 4:
Setup:
(for testing purposes - not able to have this as a final setup)
Outcome:
Scenario 5:
In this scenario, I introducted an additional switch ("B"), right next to the RBR850. Consider this the "think outside of the box" scenario.
Setup:
* Orbi Router (WAN port) -> Switch B -> Switch A -> Fritzbox Router
* Orbi Router (LAN port) -> Switch B -> Switch A -> Fritzbox Router
Yes, you saw that correctly, two cables from the RBR850 to the same switch!
* Orbi Satellite (LAN port) -> Switch A -> Fritzbox Router
Outcome:
° Not sure if it was mesh (see later);
So far, so good. However, some downsides:
* The network became very slow, even the wired parts. I also noticed that the RBR850 got two IP addresses assigned by the router. I'm guessing the router was working overtime trying to figure out what was happening.
* The GUI of the RBR850 became unreachable (I tried both IP addresses). So I could'n check "attached devices". However, there was a nice handover between both devices when I was walking around the house. So I guess I have mesh.
* The GUI of the RBS850 was accessible only if I was on the wifi of the RBS850. There I could verify that it could see the RBR850 and the both 2.4Ghz and 5Ghz wifi signals were secured.
For now, I'm reverting back to scenario 1.
The way I see it, is that this is something that can be solved in the next Orbi firmware release.
- FURRYe38Mar 01, 2020Guru - Experienced User
- Dries2Mar 02, 2020Guide
Well... I'll be damned. I must admit I didn't buy your "it's your green switch" theory. How could a switch result in an unsecured SSID, right?
But I tried this, with positive outcome:
Setup:
* All other network devices -> Switch -> Fritzbox Router (LAN4)
* Orbi Router (LAN port) -> Fritzbox Router (LAN2)
* Orbi Satellite (LAN port) -> Fritzbox Router (LAN3);
Outcome:
+ All Wifi SSID's are secured;So problem solved, I guess.
I don't really like the cabling setup. I think it is more "clean" to have everything go via the switch, with one cable to the router. But I can live with it.
I also believe that a firmware update could fix this issue as well. Depending on me using the WAN or LAN port of the RBR850 I was able to have a good (but unsecured) mesh network, or a secured (but non-mesh) network.
So FURRYe38, thank you very much!!!
- FURRYe38Mar 02, 2020Guru - Experienced User
Awesome.
Yes, Green Ethernet switch have been giving Orbi systems problems over the years. NG doesn't seem to want to do anything about it or maybe they can't. I don't know. Users in the Orbi AC forum found these to be the problem between there RBRs and RBSs so it's been one troubleshooting step I keep on the plate. Glad you configured it to work as expected.
Be sure to make a backup configuration to file for safe keeping. This saves time if a reset is needed.
Enjoy. :smileywink:
