Dries2
Feb 29, 2020Guide
RBR850 - Access Point + wired backhaul & security issues
Hi all, I've bought the RBK821 (RBR850+RBS850) combo, but it has given me quite some headache... I already have a router installed (Fritz!Boz 7590) which needs to function as a router, becaus...
- Mar 01, 2020
What impractical cabling is preventing Senario #3?
Your switch you have maybe a factor, thought its non managed, it has green ethernet features which causes problems for Orbi systems:https://www.cisco.com/c/en/us/products/collateral/switches/small-business-100-series-unmanaged-switches/datasheet_C78-582017.html
We've seen issues before with users switches having green ethernet.
Any chance you have a different switch with out Green Ethernet features?
fangruoyuan
Mar 10, 2020Guide
Hello, I have the exact issue like you in my rbk 852. And I also have the internet disconnect (magenta light show) issue. Do you see the light show in your system(AP mode)
Mar 10, 2020Guru - Experienced User
Please follow up here with your post:
Thank you.
fangruoyuan wrote:Hello, I have the exact issue like you in my rbk 852. And I also have the internet disconnect (magenta light show) issue. Do you see the light show in your system(AP mode)
