Dries2
Feb 29, 2020Guide
RBR850 - Access Point + wired backhaul & security issues
Hi all, I've bought the RBK821 (RBR850+RBS850) combo, but it has given me quite some headache... I already have a router installed (Fritz!Boz 7590) which needs to function as a router, becaus...
- Mar 01, 2020
What impractical cabling is preventing Senario #3?
Your switch you have maybe a factor, thought its non managed, it has green ethernet features which causes problems for Orbi systems:https://www.cisco.com/c/en/us/products/collateral/switches/small-business-100-series-unmanaged-switches/datasheet_C78-582017.html
We've seen issues before with users switches having green ethernet.
Any chance you have a different switch with out Green Ethernet features?
Dries2
Mar 02, 2020Guide
Hmm...
One follow up question.
When I look at "connected satellites" I don't see any value in "Connected Orbi". I recall that in one of my previous "cable setups" it had the value "Orbi Router" in there.
https://i.ibb.co/MpVzpjS/2020-03-02-16-30-50.jpg
I'm not sure if that is important, but I just noticed it.
Mar 10, 2020Guru - Experienced User
Well for my RBR the status reads "Orbi Router" for Connected Orbi section. However mines in router mode currently. :smileywink:
Using Opera browser on Mac.
Dries2 wrote:Hmm...
